Drone Hacks offers a paid app to hack DJI drones at https // www.drone-hacks.com. The main issue is the FCC mode with more transmission power / range, which is forbidden in the EU.
Depending on the drone and firmware, the altitude limit and no-fly zones can also be switched off.
The website is currently only available in English. On the birdmap you can see what can be hacked or changed with which DJI drone, with which firmware version.
Flashing and changing the firmware is free of charge, a license must be purchased for other functions.
If you only want FCC mode, you can purchase a cheaper "light license".
The app can be downloaded for free, so you can have a look at everything first.
Some interesting features are included in the app, for example a wizzard that enables beginners to optimally configure their drones.
Another thing is the parameters, which contain entire configurations as a set.
Above all, the parameters offer the possibility of exporting and importing parameter sets. This means that people with the same drone can also exchange parameters with each other. That should serve above all for the community to liven it up a little.
It is also possible to exchange these parameter sets via this forum.
For some drones, the remote control must be patted instead of the drone.
Depending on the drone, parameters of the flight controller can also be changed.
The website and the app had some bugs, which were fixed quickly.
In case of problems you can write to the support, also in German and get help very quickly.
However, all modifications are at your own risk. And you should be aware that if you increase the transmission power, you can no longer fly legally.
The patches work well and you can reset your "bird" to the original settings at any time.
And here is a gift from the Drone-Hacks team to our readers. With the coupon code " KOPTER_10 " there is a 10% discount. Simply enter this code there during the checkout process.
